How long is my stroke??
Old Aug 15, 2009 | 10:12 PM
Ben Thompson's Avatar
Default How long is my stroke??
When I measure the stroke of my motor, it is 3.25 to the edge of the piston and 3.0 to the highest point of the piston. What actually is it.
Old Aug 15, 2009 | 11:02 PM
Huh? Stroke is the distance the piston travels in the cylinder. It's the difference between top dead center and bottom dead center. What engine anyway?
Old Aug 16, 2009 | 11:47 AM
Your right, from the block deck to the outer edge of the piston at bdc is 3.25 inches. At bdc if you measure to the compression hump in the center of the piston where the recesses are for the valves it is 3.00 inches. I found that it is a 68 camaro 327 due to the MA at the end of the casting number.
The Firebird Lady
Nov 20, 2009 07:42 PM
Chappie99
Feb 23, 2008 11:15 PM
fatass91
Jul 3, 2006 09:54 PM
mike95z
Apr 23, 2006 12:21 AM
SpudieFresh
82-92 V8 Tech
Aug 14, 2005 02:20 PM
