How do i find out what engine i have?
Old Oct 6, 2008 | 07:53 PM
guest7's Avatar
Default How do i find out what engine i have?
I have a 1981 camaro its got a 305 according to the title but i think it has been changed a few people have been telling me 305/350 personally i think its a 305. Can anyone tell by these numbers on the motor? 18436572 If not where can i find numbers that could be useful? Thx for reading![:-]
Old Oct 6, 2008 | 08:06 PM
bobarian91's Avatar
BackseatBob
Default RE: How do i find out what engine i have?
Well, if no other way you can pull a head off and check the size of the cylinders. A 350 has a 4" bore, a 305 is noticeably smaller.
Old Oct 6, 2008 | 09:09 PM
GRIFF's Avatar
That number is the firing order off the manifold look on the rear passenger side part of the block where the trans bolts onto..... This is a link to the block casting numbers http://www.mortec.com/castnum.htm
Old Oct 6, 2008 | 09:32 PM
You found those numbers on the intake manifold, and they are your engines firing order.
Look on the block, drivers side near the bellhousing for the casting #. That will tell you what the engine might be. Near the casting #, or in the same place on the passenger side will be the date code. And the numbers stamped on a pad in front of the passenger side head will tell the rest.
http://www.chevy-camaro.com/chevy-ca...oding-help.asp
bk1981
May 29, 2013 09:47 PM
Banditz
Nov 22, 2010 12:30 AM
bthackrey
Jul 12, 2010 09:36 AM
87BumbleBee
Mar 17, 2009 07:41 PM
Mikevogel
Nov 8, 2005 12:00 AM
