Freeze plugs
Old Mar 3, 2006 | 02:15 AM
ChrisDK17's Avatar
Default Freeze plugs
Garggle. i was working on my camarotoday and I was almost ready to fire it up i just needed to flush radiator and refill check for leaks and stuff. then my smartass brother came out and said hummm...... you might wanna check the freeze plugs.
I hate it when my brothers right. anyhoo is it next to impossible to change the freeze plugs in a 1980 305 v8 with the engine installed in the car? also i checked for plugs and they had both copper and steel plugs at around the same price, Which is better?
Old Mar 3, 2006 | 02:48 AM
bowtieguy's Avatar
July 2009 ROTM
Default RE: Freeze plugs
most of the we just knocked them on in and installed the new ones,they are to big to get in to anything,ive always used the metal ones,never had a problem,just make sure you use silicone or that yellow 3-m glue ,wipe it around the plug before you put it in.make sure it is nice and dry.if you had a slide hammer you could drill a hole in the plug and try to pull the plug out,that sounds to much like work to me especially in the car body.
Old Mar 12, 2006 | 03:05 AM
v8chvyguy's Avatar
Get a punch, tap it at one end and knock it sideways, then pull it out with a vise grips. I use indian head when I install new ones it seals way better than silicon and monkey snot. use the brass core plugs they dont corrode like the steel do.
thebandit110
Aug 14, 2009 10:31 PM
superROB23
Mar 24, 2007 04:05 PM
superROB23
Mar 20, 2007 03:34 PM
z28scorpio
Mar 11, 2007 07:53 PM
superROB23
Oct 1, 2006 11:57 AM
