engine swap
Old May 17, 2005 | 02:20 AM
camarogirl97's Avatar
Default engine swap
i have a 97 camaro v6 3.8 series 2..comes to find out i mite hafta replace the motor.. is it possible to do an engine swap and put a v8 in..and if so what would hafta be done? because honestly i'd have alot less problems with a v8 cuz v6 camaros are junk. thanks alot.
Old May 17, 2005 | 10:13 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: engine swap
seems like i keep answering this one....time to make a FAQ section patrick! the answer is everything! tranny, computer, rear, motor and trans mounts, wiring harness, just about everything from a V8 camaro would have to be swapped into your V6 body to do this swap. hope this helps
Old May 26, 2005 | 01:46 AM
69rat's Avatar
your best bet is to pull out the cross member with the v8 engine you will be swapping in still in tact and install that. you will obviously need the computer and possibly the trans if it is a stick. i know on LS1 swaps you need the fuel lines as well. prepare for a lot of work if your gunna do it. good luck.
3800_seriesII
Aug 14, 2012 07:24 AM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
cachaco736
Dec 11, 2007 11:12 AM
uradumass5695
Oct 21, 2006 08:27 AM
illumastar
Oct 20, 2006 01:42 PM
