Engine rebuild
Old Aug 12, 2012 | 10:29 AM
cchoneycutt's Avatar
Default Engine rebuild
Hello all, looking to hopefully get some advise I'm in the middle of rebuilding my engine 350 standard bore, eagle rods, the problem I'm running into is #3 & #5 connecting rod bolts hit on the far side of the block. Tangs are facing out and both on same side. I've even went as far as taking the #1 piston out and trying it in their spot, with the same results? Any ideas?
Thanks,
Cecil
Last edited by cchoneycutt; Aug 12, 2012 at 03:03 PM. Reason: additional information these are eagle I beam rods and not hitting to bad.
gagemonster
Jul 18, 2011 08:57 AM
ultra94z
Jan 2, 2009 09:05 AM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
mineornone
Nov 1, 2007 07:58 PM
Ryanp81
Sep 22, 2006 11:27 PM
