is it easier to rebuild a 305 or a 350
Old Jul 8, 2008 | 03:39 PM
89RSmemorial's Avatar
Default is it easier to rebuild a 305 or a 350
ive got an 89 rs and there is a 305 in it but i didnt know if its better to just rebuild that motor or find a 350 and rebuild it!! also how hard is it to rebuild the transmission in it and will it work with a 350 if i get one!!
Old Jul 9, 2008 | 07:58 AM
bluovlh8er's Avatar
Default RE: is it easier to rebuild a 305 or a 350
what are you doing with the car? keep in mind... it takes a lot of money to make the 305 as fast as the 350. why not start with the 350?
Old Jul 9, 2008 | 08:01 AM
i want a good motor but im not sure how to tell what 350 are in good condition
Old Jul 13, 2008 | 09:40 AM
blackz87's Avatar
The best results would be to replace the 305 with a Gm crate350 . (long block @$1400). Most external parts from the 305 will transfer over including the intake and TBI. You will not have a performance screamer but it still will over what you would have with rebuilt 305.
Old Jul 13, 2008 | 10:16 AM
BigNic's Avatar
4' 11" 117 lbs of fury!
like spectar said as long as the engine is in good condition youll be fine. second you can run a 75 wet shot with a ball park tune with no problems and a 100 shot if you go in and tune it well. ill be putting a 75 shot on mine as soon as sombody finshes his Mcats.
Old Jul 13, 2008 | 11:19 AM
im trying to get around 400 to 450 hp . using new cam bore it out pistons heads headers, ive got headers picked out but the rest of the stuff im not sure about. im getting a short block 350. Thanks for the help. ill have pics of the car up soon
Old Jul 13, 2008 | 04:54 PM
blackz87's Avatar
Went from a 305 rebuild and not knowing anything about a good 350 block to now a fire breathing 400/450 HP bored out 350. Go figure?????[sm=bounceybounce.gif]
Chaotic94
Jul 23, 2013 04:27 AM
mikes68
70-81 Transmission & Differential
Apr 29, 2013 02:59 PM
iLL95
Sep 1, 2011 10:34 AM
PeterM17
Dec 8, 2007 10:14 AM
