changing my spark plugs!
Old Sep 29, 2008 | 11:50 AM
pimpdd101's Avatar
Default changing my spark plugs!
so i have a 2000 z28 and i cant change the plugs and wires on the passenger side. whats the easyist way to do so?
thanks
Old Sep 29, 2008 | 08:26 PM
ralphz28's Avatar
Default RE: changing my spark plugs!
I had that exact same problem on my 1991 camaro, man, they were a pain to get to. I had to jack the car up slightly and go underneath the the passenger side to get to them. Only major thing in the way was the starter (positive and negative posts exposed, ouch) and the engine mount and suspension arm. other than that, it was a sinch. I'm not sure how the 4th gens are set up, but i also removed the o2 pump on the passenger side, so i could get some help from the top too.
Old Oct 5, 2008 | 09:08 PM
BlueKitsune's Avatar
I myself did all the Drivers side plugs on my 89 from the top but on the passengers side I had to get them all from the underside oh and an pivot REALLY helps
Old Oct 7, 2008 | 09:45 PM
elias_799's Avatar
i took of the egr (small pipe connected to you exhaust manifold) and then you have access to 3 of 4 on the passenger side and for the last one you need to go under the car. drivers side was pretty easy.
Chaotic94
Jun 20, 2010 09:13 AM
Skyline
Oct 14, 2009 10:02 PM
Spartan66
Apr 7, 2008 11:49 AM
Camaro Z28
Feb 6, 2008 10:39 PM
red99camaro
Jul 13, 2007 02:31 PM
