help with changing spark plugs?
Old Feb 6, 2008 | 05:32 PM
Camaro Z28's Avatar
Default help with changing spark plugs?
I have a 97 Lt1 and i already changed the drivers side spark plugs and wires, now when I went to the passanger side, it was impossible to change the wires and sparkplugs, Can someone please give me a detailed descrption on how to change the wires and spark Plugs on the passanger side Please!!!!!!!!!!!!
Old Feb 6, 2008 | 06:51 PM
Spartan66's Avatar
Default RE: help with changing spark plugs?
jack the car up and put it on stands as high as you can get a rather long ratchet attatchment. its do able. its supposed to take several hours is what im told. Took my mechanic 3 for the WHOLE thing. but he doesnt have a floor lift so he had to use jack stands.
Old Feb 6, 2008 | 10:39 PM
95slvrZ28's Avatar
Some of the passenger side plugs are easier from the top, some from the bottom. There's no way you're going to get plug 2 (the one closest to the front of the motor) from the bottom, and plug 4(the second one) is easier from the top as well. Plug 8 and 6 you can get from the bottom, if you have skinny arms you can probably get to plug 8 pretty easily, if you have bigger arms you may want to consider taking out the starter, which makes it much easier to access.
Chaotic94
Jun 20, 2010 09:13 AM
Skyline
Oct 14, 2009 10:02 PM
Spartan66
Apr 7, 2008 11:49 AM
red99camaro
Jul 13, 2007 02:31 PM
badpig
Jan 5, 2007 12:47 AM
