big problem
Old Oct 17, 2010 | 06:37 PM
DC1Camaro's Avatar
Default big problem
hi, i am rebielding a 94 camaro it is the lt1 and i am making it into a 383 stroker. i put the crank and pistons in and was ready to put the heads on it but i noticed that the piston comes up way far so i but the head on top and smashed it flat, turned the crank and it hit the head. why is it doing this. i think maybe the connecting rods are to long. they are the 5.7 rods. is that true? what size do i need.
Old Oct 18, 2010 | 01:52 PM
Wrong pistons for the stock rods and stroker crank. You need pistons with the wrist pin moved closer to the piston crown.
Old Oct 18, 2010 | 01:56 PM
As they say in China...Sum-Ting-Wong! Did you buy this as a "stroker kit", or are you putting the parts together?
Old Oct 18, 2010 | 04:27 PM
DC1Camaro's Avatar
ya that makes sence. the piston problem and no i didnt buy it in the kit. 1.5 years ago i didnt make enough money to(stupid on my part) and now i have almost everything just need push rods, injectors, lifters, now pistons, and intake. any suggestion?
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
