any performance from fuel injectors?
Old Jan 22, 2007 | 11:33 PM
microkid's Avatar
March 2011 ROTM
Technical User
Default any performance from fuel injectors?
i dont think many people have though about it, but are there any gains from replacing the fuel injectors? are there any upgrades out there? how much are new injectors anyway?
Old Jan 23, 2007 | 01:02 PM
JD1969's Avatar
Default RE: any performance from fuel injectors?
If your old ones are maxed out or clogged so bad that they can't be cleaned then yes. You won't need bigger injectors untill you have a big cam and heads in most cases.
Old Jan 23, 2007 | 10:59 PM
microkid's Avatar
March 2011 ROTM
Technical User
well, i was concerned about them being dirty because after running some dry gas and injector cleaner, the number one cylinder was still running lean. it had a minor ping comming from that area, and the prongs on my bosch double platinum plugs were pushed inward (but not melted)
Old Feb 10, 2007 | 06:55 PM
microkid's Avatar
March 2011 ROTM
Technical User
would you guys recomending replacing/upgrading if i am going to do be doing more performance work to it? i plan on a few minor things, namely headers, some intake things, and a computer chip and ignition.
Old Feb 16, 2007 | 03:35 PM
IanM's Avatar
My .02: unless you're really going to be burning a lot more fuel, I don't think it would be worth your time. If you work on the internals and end up having big numbers, then it might be a good idea. Save up and get some nicer heads and a cam, like JD 1969 said.
Old Feb 16, 2007 | 04:35 PM
blackz87's Avatar
I would get your injectors cleaned and checked, well worth the money. Right now the stock injectors are 19 # and on a 305 even with mods, larger ones will not help performance. Ifyou go larger you will also require a custom chip to increase fuel by the ECM. My opinion. Cost of replacement for the origional GM parts are about $100 EACH and you can find cheaper ones but they will be that " Cheap".
301Breed
Mar 31, 2011 08:57 AM
gville4life
May 23, 2010 02:19 PM
aightball87
Sep 16, 2008 04:18 AM
JHL88
May 21, 2007 04:24 PM
countryboy
Feb 16, 2007 09:57 PM
