LT1/LT4 Tech 1993-1997
fuel injectors
Old Sep 14, 2008 | 10:44 AM
aightball87's Avatar
Default fuel injectors
whats the best place to get a good set of injectors on a low budget? if i upgrade the injectors from 24lb to 30lb injectors will it be fine until i tune it?
Old Sep 14, 2008 | 07:04 PM
95slvrZ28's Avatar
Default RE: fuel injectors
Why are you upgrading your fuel injectors? The stock injectors provide more than enough flow for a bolt-on car. If you've done internal work (cam or heads) you can consider 30# injectors, but if you don't have much done to it I wouldn't waste your time or money on new injectors. If you decide that you really want them it would be a good decision to get a tune along with them.
Old Sep 15, 2008 | 11:13 AM
whammer3024's Avatar
ROTM Winner
yeah i'm pretty much full bolt on right now and my stock ones are fine. when i get the heads and cam package this winter i'll probably upgrade to 30# ones
Old Sep 15, 2008 | 11:44 AM
95slvrZ28's Avatar
30# injectors will easily hold 400 RWHP, so the stock 24# are fine until you get into the head/cam packages.
Old Sep 16, 2008 | 04:18 AM
well i plan on doing the heads and cam when tax time comes around and the 30lb injectors are the same price as the 24s at summit so i figured id better upgrade while i need them.
Mikey.
Nov 6, 2011 09:41 PM
jdoggrr
Apr 26, 2008 07:06 AM
3.4CamaroCDOG
Feb 10, 2008 09:41 PM
countryboy
Feb 16, 2007 09:57 PM
60DegSpeed
Jul 24, 2006 02:08 AM
