Aftermarket heads
Old Nov 25, 2008 | 09:08 PM
pockets47's Avatar
Default Aftermarket heads
Ok im buying new heads and im trying to figure out. Out of the 2 im picking from which one is better, makes more power, and which is more reliable. Either the LT1 LE2 heads from elliotportswork or the CNC'd 200cc competition LT1 cylinder heads from advanced induction.
Old Nov 26, 2008 | 04:20 PM
whammer3024's Avatar
ROTM Winner
Default RE: Aftermarket heads
neither of them will be better than the other. they are both great companies that do great work and get great results from porting stock heads. i'm going with lloyd elliott if it helps you at all. you should be able to talk to them and let them know what you're thinking and all about your car and they will give you their estimates on the horsepower they'd expect you to make. i wanna say the le2 package is like 390-420 depending on the cam
Old Nov 26, 2008 | 06:46 PM
pockets47's Avatar
Yea i talked tollyodhe said thw LE2 heads with a custom cam 223/231 .565/.583 112 LSA. He saidwould probally be the best with pushing (8psi). He said i will have 500-550 RWHP with the 383ci stroker assembly, LE2 heads the custom cam and the procharger with 8 (psi).butim getting the assembly through advanced induction dont you think there heads and cam will work better with there assembly. Or do you think im beeter off getting advanced induction assembly and llyod"s LE2 heads and cam. thanks
Old Nov 29, 2008 | 08:24 AM
ROTM Winner
again, if you tell lloyd exactly what you have, he will be fine. i'm one of those guys that if i buy something from one guy, i'm going to get the rest from him too. but that's just me. lloyd will definitely make things work real well forya if that's who you want to go with
BlackOps
Sep 23, 2010 07:51 AM
fbodyhemi69
LS Series Tech
Dec 7, 2009 05:16 PM
SixShooterCamaro
Oct 30, 2009 08:58 PM
1983_JAL
Mar 23, 2007 11:57 PM
