Detailing Discuss detailing your ride within.
Primer help
Old Mar 20, 2008 | 04:20 PM
Saint_Ali's Avatar
Default Primer help
well i have been using the rustoleum primers, ive used the darker black and the grey primer, but it seems when i go to wet sand it you can see the swirl marks from wet sanding it, what should i do ? i just want it to look half way decent
Old Apr 1, 2008 | 10:31 AM
1969 SS's Avatar
Default RE: Primer help
use a finer sandpaper. are you saying your wetsanding your primer?
Old Apr 4, 2008 | 07:38 PM
Saint_Ali's Avatar
yes im wetsanding with 600 grit, thats the finest i could find locally
Old Apr 4, 2008 | 08:56 PM
FlightMechYJ68's Avatar
You will probably have to go to an actual bodyshop to get anything finer... that or on www.eastwood.com not sure about the price though...
Old Apr 5, 2008 | 01:59 PM
1969 SS's Avatar
what are you painting
are you just seeing the fine swirlmarks, or are you actually seeing scratches? swirlmarks are normal. this is why after painting cars get sanded with 1200-1600 grit paper and then get buffed to get rid of the fine scratches
600 grit sandpaper is actually a lot smoother than you should be using. the primer is there to protect and help with adhesion so you actually need some type of surface finish for the paint to stick to
Old Apr 19, 2008 | 07:05 AM
JJ_77's Avatar
You should be able to find finer grit sand paper (800, 1000, 1200) at a local paint store such as sherwin williams, porter paints, ICI, etc. Used a lot for laquer projects, so they carry it.
Old Apr 23, 2008 | 12:25 PM
1969 SS's Avatar
most of the time 400 grit should be the finest used to wetsanding primer.
greenmachine96
Mar 20, 2012 05:33 PM
mgg4591
Nov 27, 2011 10:21 PM
mikemaccham
Nov 19, 2008 11:04 PM
johnnythehmc666
Jan 28, 2008 05:48 AM
ScottD
Nov 8, 2006 09:01 PM
