Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
converting efi to carb
Old Aug 27, 2007 | 02:01 PM
hinesy4's Avatar
Default converting efi to carb
Iknow i read a post about this topic that went into good detail a while back but i cant find it now, so sorry to repeat. I am putting a carbed 350 into my previosly fuel injected86 iroc. What is the best solution for the new fuel pump?Am i best going withthe block-mounted mechanical pump and running new fuel lines? I may be dropping the tank to either clean and reinstallor switch outwith fuel cell. Any suggestions on that? And if i am dropping the tank, would i be better off installing an in-tank pump? Any suggestions will help since I have never done any of this before.
Old Aug 27, 2007 | 08:13 PM
SickSickSick's Avatar
Default RE: converting efi to carb
Carbs are designed to run with a mechanical pump. The BEST way is to find an older tank or fuel cell and replace the one built for fuel injection and use a mechanical pump.there are LOTS of easier ways but the tryed and true way will translate into the least amount of problems down the rode. thats been my experience anyway. Sick
Old Aug 28, 2007 | 08:57 AM
hinesy4's Avatar
Thats what i was thinking, thanks a lot.
fbodyhemi69
Jul 28, 2010 09:44 AM
Harkes2k
Oct 5, 2008 05:24 PM
JMAC09
82-92 V8 Tech
Mar 13, 2008 07:09 PM
sven96Z28
Feb 1, 2007 11:23 PM
blcp86
Jul 7, 2006 04:31 PM
