Specter/Slvr = Care to Join Me?
#74
Wow...Alright Paz, I'm going to try and answer all of your riddles in your language...let's see how this goes:
Yo oar re diddle is question is not the camel on the doorknob. Specified have not you whether oar is not piston is cylinder in question. 1 could is answer, but potentially is small level molecule on Ohms law. 2 is could answer if off motor is turning none. Is air move pressure it is make with fast. 3 answer is not unanswer becuz cam not is made correctly, recommend new one is on my eye soar. Is you right 14.7 happens all time, but is we are care relative pressure exhaust we talk is about. Is you under stand ying my fallacy now? OTTO would be pissed in you oar dixie cup relating his creation is Ohm's law. Is I know all sensors voltage use, but lightning speed is not air speed travel why. Lightning IS travel air through due to ion I zation not fast air traveling. I think you is not undersand fizz sicks as well is you are think on a basis that is not is normal. You follow my epic tech is not you are fault from racing.
Did I get that right guys?
#76
God help me I cant stay out of this thread. Maybe I do like S&M after all.
#77
Slvr. I had a long drawn out responce.... it was actually related to the cam being too big... I could discern only a little of what his 'correct answer' was. you are good.
#78
Ya...I want to know if that made no sense at all...that would be right in his eyes. I thin..., I'm still not sure because the camel's back hasn't revved the engine upside-down under a full moon while urinating onto a squirrel under a tree worm.
#80
