where to mount my amp?
No, what I've seen done is if you make it to wear it fits the whole space on your back deck, from the back seat to the start of your box, and from side panel to side panel, it will set there and not more unless something bad happens. I've seen people use velco on the bottom of the riser pieces to make it stick to the factory capet there. Just do a search for camaro amp rack and you'll see a lot or different ones. If you have more questions about building one or whatever, just let me know and I'll help you out.
It will look much better and it won't leave holes in your car if you decide to upgrade componets or whatever. I've built several, so if you want any help or info. just ask.
