My IROCZ Audio
Old Nov 9, 2007 | 11:15 AM
Auji350's Avatar
Default My IROCZ Audio
I have already posted about this in a different thread, so im going to post it in the right thread. I didn't get any responses yet so, here it is.
The link to my questions.
Please add your comment, thanks! https://camaroforums.com/m_131003/tm.htm
Old Nov 27, 2007 | 08:16 PM
Duffman's Avatar
Default RE: My IROCZ Audio
Idk about the altinator but you might want to get a circuit breaker so that instead of blowing expensive fuses you can just flip a switch. Also you will need at least a 1 farad cap.
Old Nov 29, 2007 | 02:41 AM
CRanMaro99's Avatar
April 2008 ROTM
No, you will not need a cap.
Old Nov 29, 2007 | 02:40 PM
Duffman's Avatar
Hes runnig a 1200 watt amp and unless he wants his cars lights dimming and his sub not hitting to its fulll potential then I guess your right and he wont need one.
Old Nov 29, 2007 | 07:29 PM
CRanMaro99's Avatar
April 2008 ROTM
A cap is only a band aid for what the real issue is. A cap doesn't fix anything.
I would first upgrade the "Big three" electrical in your car, as I am sure it is needed. Then if there is still dimming upgrade your battery. If that doesn't work then you need to get a bigger amp alternator. That is the way it goes.
But first install everything and if you don't have dimming, you wont have to worry. no need to spend money where it isn't needed. I'd still recommend upgrading the big three anyways.
Here is how and what it is:
http://www.caraudio.com/forum/showthread.php?t=152355
FEC Sledge
Aug 28, 2014 04:01 PM
BlackIceZ28
82-92 V8 Tech
Mar 15, 2007 03:30 AM
Chooseup
Mar 1, 2007 05:48 AM
Chooseup
Feb 28, 2007 12:23 AM
irocz1985
Apr 20, 2006 08:03 PM
