Halo - Angel Eye Mod 93-97
so you used a different set of lights for the high beams? (the driving light had one bulb for the ring and the high beams have two bulbs in the ring). Can you give me the name of the lights you used for the high beams, i would like to make both of my lights with the two bulbs in the ring.
thanks
thanks
The box, name, and model number were exactly the same as before. I bought them at pepboys, same place i got the others. You might want to contact pilot for the double bulb ones. The box looks the exact same, even the model number.
I would like to know if you HAVE to drill into the top of the headlight bar, ive scene another where they drilled and mounted to the bumper itself. Is there any other way to mount it with the current housing? or is this the easiest way?
Exactly which lights did you use? Can you post a link to the ones you bought. I really want to do this conversion to my car. I want the LED's to come on with an aftermarket switch and the HID's to come on with the factory switch. Also want to do the brights (LED's to turn on with the same switch as the low beams, and HID's's to turn on with the factory brights switch). Basically I want the lights to function as my factory lights do and I want the blue ring to come on by a aftermarket switch. How would I wire this? Also, will the brights actually be brighter than the low beams? Is it a different light?
its on the first page in case you didnt see it.
