can some answer this? AMP
Old Jun 24, 2008 | 05:38 PM
LT1RUNNER's Avatar
Default RE: can some answer this? AMP
Not all mono amps power only one speaker. Quite a few are made to power two speakers as well and a mono amp is an amp that filters out the highs and is made soley for woofers. If your amp puts out 750 rms is this @ 2 ohms or 4?? If the amp pushed 750 watts @ 2 ohms and you only run 1 -4 ohm woofer then you will only get half of the output the amp is capable of or 375 watts. Are you confused now?
bear9820
Nov 15, 2010 12:42 PM
chewybacca11
Aug 31, 2010 04:06 PM
rs305
Mar 29, 2007 01:31 AM
jhop16
Dec 27, 2006 03:59 PM
