Maybe someone can answer this
Old Mar 25, 2007 | 03:31 AM
rs305's Avatar
Default Maybe someone can answer this
I didnt really get a straight answer last time but ill try again. Does anyone know how 18 inch wheels with 245/40/18 tires will fit on my 92 rs.
Old Mar 25, 2007 | 04:50 AM
MadMikeZ28's Avatar
Default RE: Maybe someone can answer this
You do not even give a straight question last time or this time!
What wheels! Just asking if 18's will fit does not cut it![:@]
Old Mar 25, 2007 | 05:22 AM
74454bb's Avatar
May 2007 ROTM
Yep, they will fit with the right back space.
Old Mar 25, 2007 | 03:59 PM
microkid's Avatar
March 2011 ROTM
Technical User
i dont think they would fit on the front, and it would probably look really stupid too
Old Mar 25, 2007 | 06:04 PM
jliroc's Avatar
I think you are very wrong micro kid..... check this ride out, 18x8 all the way around, no rubbing and looks better than I have ever seen. Had to roll the fenders and put heavy duty springs in the front. otherwise its great. This car belongs to a guy I have been talking to. I had the same question for my ride rs305...
[IMG]local://upfiles/7219/09B8AE7083734671946C276DDE3B137A.jpg[/IMG]
Old Mar 25, 2007 | 06:06 PM
rs305's Avatar
ok mad mike. they are 18x8 chrome iroc replica wheels with 4.5 backspace and 245/40/18 tires. What other info do you need?
Old Mar 25, 2007 | 08:32 PM
MadMikeZ28's Avatar
In the wasted space on your other post I told you a tire size and offset that will fit. You did not give an offset so how did you expect a straight answer?
I told you a 4.5 to 4.75 will fit. Now that you have fnally shared that info we know the wheel has the proper offset. Now you can use the suggested size I gave that will fit of 255/45 and I staed its on a 17x9 wheel. Yours is an 8 so thats even better. And you can look all over the web for a tire size calculator.
What you will find is that between the size I told you will fit and the size you are going for will fit due to the size you want being ever so slightly smaller.You have a better chance of getting the answer you are looking for if you give the proper info.
Old Mar 27, 2007 | 09:00 PM
350DREAMS's Avatar
18's on camaro = ricer
Old Mar 27, 2007 | 09:04 PM
MadMikeZ28's Avatar
ORIGINAL: 350DREAMS
You know the big wheels are not bad until you cant lower the car enough and the rockers are a foot off the ground.[:'(]
Then your car becomes a sport ute
Old Mar 27, 2007 | 09:48 PM
350rs's Avatar
March 2008 ROTM
i agree, a friend of mine has 18" torqe thrust 2's on his car, looks strange to me, sick with a 17 or 16. But thats just my opinion on style... i like a little sidewall on my camaro.
