Antenna Options
Old Aug 21, 2008 | 05:00 PM
FUZZYDP's Avatar
Default Antenna Options
Looking for good hidden antenna for my 69 or suggestions. Prefer not having a mast powered or not. Need advice based on use.
Old Aug 21, 2008 | 08:05 PM
02StanGT's Avatar
Default RE: Antenna Options
AutoLoc is what a few on one of the other forums I check out. I bought a hidden antenna from them with intentions on shaving the stock antenna. It worked when I tested it. Actually was not badsounding for me having it in the trunk. When I get it all said anddone with it will be mounted on the inside of the back window(which will be better than the trunk). I did have to get an adapter to get the antenna wire to connect with the stock one.
Old Nov 2, 2008 | 01:15 AM
Skippysnax's Avatar
metra makes an amplified antenna that can be hidden behind the dash
Old Nov 2, 2008 | 09:25 PM
FUZZYDP's Avatar
Did the custom autosound amplified & even put a stock mast under the dash & they suck. Guess power antenna. Just hate to loose the smooth lines.
Thanks
Chevy101
May 29, 2011 01:49 PM
bayman88
Dec 13, 2009 05:39 PM
cautioncones
Dec 27, 2008 06:06 PM
shnormo
Oct 11, 2006 06:06 PM
