Aftermarket CD instalation question
Old Feb 21, 2008 | 04:45 PM
arpinj's Avatar
Default Aftermarket CD instalation question
I am trying to insall a sony exploud CD player in my 1994 V6 and in the back of the old delco bose CD player the AM/FM radio hook up is going directly into the old CD player. what do i do with that do i just cut it and wire it into the new one? I dont know pleas help me
Old Feb 21, 2008 | 09:34 PM
sicked_wick's Avatar
Default RE: Aftermarket CD instalation question
there shouldnt be anything like wired into your delco. Should just be something you unplug. Your antenna cord, and a bunch of little wires for the speakers and and ****. then possibly a ground or a power wire...idk i havent seen the back of my delco since i sold it
Old Feb 21, 2008 | 09:39 PM
I have a pic of it all taken out if you want it?
Old Feb 23, 2008 | 11:10 AM
arpinj's Avatar
sure i have a friend who knows about all that stuff he said it should just pull out. it just looked like it was wired directly into the unit
Old Feb 24, 2008 | 07:02 PM
no...there should be about (3) things you just yank out of the back of the delco
Old Mar 3, 2008 | 08:52 PM
arpinj's Avatar
No there was just 2, but now i have it prettymuch hooked up but there is no sound coming out of the speakers, what do i do now?????
Old Mar 3, 2008 | 08:57 PM
SpecterGT260's Avatar
Ninja Administrator
nonononono guys,
he only needs a wiring harness. go to best buy and get an aftermarket radio harness for ur car, it will plug into the plugs that were plugged into the back of ur stock radio (if that makes sense.....) and then u just splice those wires to the wires which plug into ur new radio........ plug... [&:] sorry, thought i was skipping there for a minute.
the audio section of best buy has a whole wall of them made for every car imaginable. makes it quick and easy because they are all colorcoded just like the wires coming out of the back of ur new deck
Old Mar 8, 2008 | 10:31 AM
arpinj's Avatar
yea i did all of that allready but when i get it pluged in the new cd palyer turns on and shows that it is playing but no sound comes out of the speakers, and i have no idea what to do about that
Old Mar 8, 2008 | 02:27 PM
3.4CamaroCDOG's Avatar
u have to give power to the amps i had the same problem
there should be a leftover blue w/ white stripe wire that is tucked under the paper on the wiring harness
i connected that to the other blue wire on the other part and thus i had sounds hope this helps
Old Mar 9, 2008 | 09:32 PM
arpinj's Avatar
i dont have an amp, i know they come stock with one but i dont remember seein a wire for that, but i will definitly look again,
