Aftermarket CD instalation question
Old Mar 9, 2008 | 10:02 PM
arpinj's Avatar
Default RE: Aftermarket CD instalation question
i just looked at the wiring plugs and on the plug that goes into the new cd player there are 2 wires that i am not using one is blue with a thing on it saying ANT REM MAX 0.1A the other is blue with a white strip, with another thing saying AMP REM MAX 0.3A. they are not wired into anything, on the converter i got there is a dark blue wire but it is wired to a diffrent blue wire. should that be connected to the wire saying ANT REM MAX 0.1A or the other one maybee, i will try to connect them together and see if that fixes it.
Old Mar 9, 2008 | 10:15 PM
SpecterGT260's Avatar
Ninja Administrator
the blue wires are usually your power antenna signal, camaros do not have this so it doesnt matter for you. I had to use one however in my TA. they only tell the power antenna to go up or down. the AMP one may be an amp on/off signal wire. I dont think you need to use that, its usually for an aftermarket amp. i am not 100% but even with monsoon, the factory amp knows to turn on/off without this wire. the difference being that most aftermarket amps are powered directly from the battery with a bigass fuse
klong2194
Jan 12, 2012 11:42 AM
masonhoban
Dec 8, 2009 06:51 AM
red70camaro
Jul 23, 2009 03:32 PM
MoreLikePALcohol
Jul 18, 2006 11:24 PM
wishmaster
Aug 3, 2005 10:40 PM
