windshield washer aiming?
Old Dec 22, 2014 | 04:11 PM
TonyGoneHiking's Avatar
Originally Posted by GaryDoug
Forget about the glue. There's a simpler solution. Just drill a hole in the vent panel at least 3/4 inch from the edge (to avoid the glass) and install a small screw into the metal underneath. You can make one pretty much anywhere its' needed to pull the panel down to the glass. Paint it black or gray to match.
So I just found out that the solution is hitting the actual wiper arm and blade but not the glass. Any idea what can be done about that?
Old Dec 22, 2014 | 04:21 PM
GaryDoug's Avatar
What? That is normal. Once the sprayer starts, the wipers will start wiping. There is no way to prevent them from moving. I thought you said it was just too high?
Old Dec 22, 2014 | 04:24 PM
It starts spraying, hits the wiper and then the wiper moves. While its out of the way, the solution BARELY hits the window, it shoots over, and when the arm comes back down it blocks the stream all together.
Old Dec 22, 2014 | 10:08 PM
GaryDoug's Avatar
Once again..... that is normal for the spray to hit the wipers before they get out of the way. If you examine the positions of them it is obvious.
You seem to be saying you have the same problem as in your first post. Have you even tried the fixes mentioned???? Mine is working just fine now.
Old Dec 23, 2014 | 08:48 AM
agree with gd turn the key on and run the wipers with the washer going and hold the plastic piece the nozzle mounts to down and see if it works right.
Old Dec 23, 2014 | 09:42 AM
I'll give that a shot tonight. Thanks for the help, everyone!
TonyGoneHiking
Dec 23, 2014 12:29 PM
feltennova
Dec 14, 2010 05:59 AM
Barkat
Aug 29, 2010 05:13 PM
bobyo
Jun 20, 2009 08:43 PM
1989_RALLYSPORT
Oct 25, 2008 10:29 PM
