Windows not rolling all the way up
Old Nov 15, 2012 | 02:21 PM
wayne242's Avatar
Default Windows not rolling all the way up
Thought i would post this in case some one else is having a related problem. I was told it was a bad motor, and also told it was how the wiring is to the windows. Both in correct for my problem, and this is something worth checking out be for buying anything for your camaro.
The problem was the windows on both drivers/pass would stop just short of being all the way up. I pulled the door panel off and found this:
All the bolts where lose, and fiberglass damaged as a result. Cant see the 3rd bolt, but it worked lose and already dropped out in the door.
After the fix, I used some spare brackets i had laying around(cut then a part). Just make sure you use something to prevent the nuts from digging into the fiberglass like the above pic.
I reused the same bolts that where already there, but also put lock tight on them(hint the blue). That way they don't work there self lose again.
i cut the 3rd bolt out of both pics, but oh well. I'm inpatient and don't like stopping once started on something. So just took some fast pics and went back to working.
Anyhow thought i would post this up for anyone having problems. Also if you have this problem and its rivets, remove them and use bolts.
P.S: I wish my car was painted the same color as the inside door panel, I'm guessing it as been changed be for.
John4649
Dec 18, 2012 03:01 PM
jrollings
May 18, 2012 05:56 PM
fresnoz29
Jan 9, 2010 07:03 AM
racecarchris
Aug 8, 2007 09:26 PM
glatz
Apr 8, 2007 11:22 AM
