Yet another exhaust question!
Old Jan 4, 2007 | 12:01 AM
Kardon507's Avatar
Default Yet another exhaust question!
I have a 1995 Camaro V6 3.4
I have four questions..
1. What would it take to get that mustang cobra noise, you know that high pitched yet muscle car sound.
2. does anybody get loose heat sheilds that give that metal crackling sound?
3. for your cigarette lighter, it simply doesnt work and i would like to know what to check first to fix it.
4. does anybody elses gorn work or what because i can't find it supprisingly lol
Old Jan 4, 2007 | 03:20 AM
jtvyper456's Avatar
Default RE: Yet another exhaust question!
1) Install an exhaust system, you probably won't get the Mustang sound, but you'll get a bit of rumble at lower RPMs, at the higher RPMs, it will sound really crappy, almost like a ricer.
2) With the sound, does it do it when you move down the road or just when you are sitting at an idle? If it is only noticeable at idle, get under the passenger side of the car with a hammer and tap your cat a few times, see if you hear any clanging around, if so, you need to replace the cat.
3) Check the fusebox! If it's not that, I think you can get to the wires if you take off the plastic panel that covers the underside of the steering wheel, check for shorts! It might be taking out the radio to get to the wires though, can take a look tommorow if you'd like .
4) Likely a bad wire, the buttons are/should be on the steering wheel (left and right), then again, it could bea fuse that has made your cigarette lighter quit working also.
Old Jan 4, 2007 | 11:16 AM
JaySan's Avatar
how do u replace the cat ?
Old Jan 4, 2007 | 02:17 PM
Kardon507's Avatar
K thanks for everything ill give it a look today and get back at you w/ the info.....Jon
Old Jan 5, 2007 | 06:23 PM
Kardon507's Avatar
the fuse and the horn problem is not fixed thanks a lot guys!
Old Jan 7, 2007 | 02:06 AM
badinfluenceRS's Avatar
supercharged v8...3.4 will never sound that good
Old Jan 7, 2007 | 04:53 AM
AlfredB18's Avatar
ORIGINAL: badinfluenceRS
True, but with the firing order being what it is, 1-2-3-4-5-6, it sounds decent...better than any 90 degree v6I have ever heard.
jax 73
Mar 21, 2010 02:30 PM
DKap22
Mar 22, 2007 10:43 PM
bill12690
Mar 19, 2007 03:29 AM
NomadicZ28
Jun 9, 2006 03:00 PM
Jester
Jan 10, 2006 03:12 PM
