wow! world of difference!
Old Feb 12, 2007 | 01:13 AM
98LS1Camaro302's Avatar
Default wow! world of difference!
So I changed the plugs on my 2000 camaro 3.8 V6 about 2 weeks ago. The car was a lil more responsive and ran a little better. Well, it would still cut out at higher rpms and when I was gettin on it at full throttle, poppin real bad. I thought it wasnt gettin enough fuel, so I ran some injector cleaner through it and put on a new fuel filter. Not it, still cut out. Today I changed the plug wires, and wow, no more cutting out, no more hesitation, its really responsive. I can spin the hell outa 2nd now instead of "barking" when I shift into it. Anyways, just thought id tell yall bout it, lol the car runs like a champ now. Time to start moddin.
Old Feb 12, 2007 | 01:38 AM
badinfluenceRS's Avatar
Default RE: wow! world of difference!
you must have had a really bad wire
Old Feb 12, 2007 | 01:43 AM
shnormo's Avatar
Run some sea foam through your intake manifoldvia your brake booster line and through your tank. Take some throttle body cleaner and clean off the butter fly, bore, and throttle positiong sensor. It'll restore that much more power too.
Old Feb 12, 2007 | 02:58 AM
yeah, ive used seafoam on my other cars, at work we do a tratment similar to it , imma buy seafoam and put it in out bottle, we have this thing that u fill with it and then push into your brake booster line. Then it has a valve on it to control how much goes through it, w0ot. Ill let yall kno how that goes. Ill probally do it tomorrow.
Old Feb 12, 2007 | 09:15 AM
oh and yeah, one wire was cut all up , passenger side all the way back. All of um were pretty bad though.
Old Feb 12, 2007 | 09:31 PM
bumpnbrd2005's Avatar
Default Ignition Control Module
Has anyone had any problems with their ignition control module. My car only has 49k on it, and I think it's gone bad. It's missing on cylinders 2 and 5. Does anyone know where the actuall ignition control module is? Thanks
Old Feb 12, 2007 | 11:18 PM
MadMikeZ28's Avatar
Default RE: Ignition Control Module
A little maintenance will go a long way
bumpnbird
I dont think a module would onlt affect two cylinders. Can you swap some coils around or wires? May also be a problem with injectors
mys10v8
May 23, 2011 10:41 AM
zidane_aj
Jun 21, 2010 05:06 PM
heathen
Dec 8, 2009 01:56 PM
mikej2244
Oct 26, 2007 03:03 PM
the_merv
Aug 30, 2007 12:12 PM
