wont start?
#32
Yes but you still should be able to rotate it one complete revolution even with compression building in the cylinders.
#34
I got the battery back to find out it's good but a little dead. I hooked it up, the car turned over a little. I did that maybe 3 times then it started for like 2 seconds then died with a loud sqeak type noise, I tried again it started for1 second and made the same noise, now it won't start again. I don't think that's a good sign.
#36
^^^^^ agree with craby! Your done! That squaking noise is your engine grinding itself to death.
#38
More than likely! You have a couple options. Replace with a donor, a crate engine or rebuild but if you spun a bearing and messed up the crank, you are looking at a complete rebuild with alot of machine shop work.
If you still are not sure, get someone local to come over and give you another opinion.
