Why am I redlining?
#31
RE: Why am I redlining?
Your shifter linkage could be bad happened to my '95 3.4L no problem w/trans just the linkage from the shifter to the trans...
ORIGINAL: BoricuaHec01
For example, when I accelerate faster then slow, it feels like first gear is switching to neutral.
#32
NO, follow your manual's directions as to how you should check your Trans. fluid you have to run through each gear for a few seconds, and as I recall the car should already be warmed up. Read the manual's procedure!
ORIGINAL: musicman
With the auto trans, check the dipstick with it running. Lets see where the fluid level is first.
