Wheres the Oil pump or whatever my oil light wont shut off
Old Aug 19, 2008 | 07:02 PM
Josh22's Avatar
Default Wheres the Oil pump or whatever my oil light wont shut off
I have a 1993 3.4 SFI camaro its not a z28...It says LOW OIL..But when i check my oil its over full some1 plz help me...i need to kno what i should do or what u think can help i dont kno how to reset the oil system or anything also, i feel a bad shake in my steering wheel when i drive, whats that all about anyhting about that too....Plz get back to me asap thanks so much
P.s my car seems to over heat every so often.......help with that too thanks so much guys
Joshua Russell
[IMG]local://upfiles/13784/1598CEDF6DD44D10A84BC27A3CC7F7DD.jpg[/IMG]
Old Aug 20, 2008 | 11:39 AM
greg w's Avatar
Default RE: Wheres the Oil pump or whatever my oil light wont shut off
the oil lite is probably the oil level sensor in the side of the oil pan. Mine went in my 95 and did the same thing with the "Low oil level" lite.
The steering wheel shake sounds like a front suspension or tire problem. I would worry more about that becouse a wiped out ball joint or tie rod end can ruin a day (and a fender)
SilverRunBootlegger
Mar 9, 2014 07:43 PM
dogdog130
Feb 16, 2011 02:36 PM
c4maro
Oct 14, 2010 07:12 PM
locotrician
May 28, 2010 09:07 PM
raysean22589
2010+ V6 Tech
Apr 7, 2010 06:31 PM
