what gas do you use?
Old Apr 12, 2007 | 03:18 PM
BryantD's Avatar
Default RE: what gas do you use?
I have a '99 3.8 that I built. I have .030" over pistons, and a higher lift cam which produce more compression. More compression needs more octane. So, I use plus '89 Amoco fuels only. Works fine for me, but without built engine, I suggest just plan ol regular.
Old Apr 12, 2007 | 11:57 PM
TheStig's Avatar
I use mid garde, but not nessacarly for permence. Some premium fuels put in great additives and work pretty well. all midgrade is is 1/3 premium. so I just use that to get a good octane & still get the good stuff. btw, i believe shell V-power is the best and always get shell.
Old Apr 13, 2007 | 01:24 AM
badinfluenceRS's Avatar
speedway man...
Old Apr 13, 2007 | 11:48 PM
BigNic's Avatar
4' 11" 117 lbs of fury!
ORIGINAL: MadMikeZ28
I use *** gass. After I eat mexican food my farts are high octane!
But when I have not had lunch I fill up with the mid grade 89
third stupidest thing ive ever herd in my life *** gass come on
Old Apr 13, 2007 | 11:54 PM
Saint_Ali's Avatar
lmao, i mostly use shell or chevron premium, but since gas has gone up shell is the most expensive so i might just use chevrom\n
Old May 7, 2007 | 04:51 PM
98v6maro's Avatar
the only way ure gonna get any power outta a higher octane gas is if ure car is tuned for it.. if not then ure really jus wastin ure money in the higher grade gas
Old May 7, 2007 | 08:00 PM
v6camaro00's Avatar
i use 93, but my car is tuned for it, and the only way you can tell is if you are tuned, and or bulit
Old May 7, 2007 | 10:44 PM
Camaroguy87's Avatar
I use regular in mine.....works fine for me.
Old May 8, 2007 | 12:05 AM
Raidenvaga's Avatar
I used 94 , racing gas , E-85 all day long, just playing
Old May 8, 2007 | 03:54 PM
  #20
95camaro's Avatar
It may just be me but i have a 3.8 i havent noticed a difference in power or anything but i think with md-grade i get better gas mileage. I use both. I normally use regular but ill fill up with regular 2 times the third time i use midgrade. It helps to keep the injectors clean.
