v6 swap
Old May 18, 2007 | 08:08 PM
tha_forbidden's Avatar
Default RE: v6 swap
What is a FI kit?
Old May 18, 2007 | 10:21 PM
badinfluenceRS's Avatar
Default RE: v6 swap
ORIGINAL: tha_forbidden
What is a FI kit?
Forced Induction aka Supercharge or Turbo
However, those are probably the least smart idea, although possibly the coolest
Old May 18, 2007 | 11:26 PM
v6camaro00's Avatar
Default RE: v6 swap
there is a *** load of stuff that is diff
Old May 18, 2007 | 11:34 PM
Default RE: v6 swap
Also LT1 swap ~3,000ish
V6 Build ~5,000ish
TONS of factors tho
Old May 20, 2007 | 01:19 PM
CamaroKid16's Avatar
Default RE: v6 swap
Is it that difficult not to swap a fuely but a carbed 350 instead of a v6. yank the wiring. Fuel is simple. rear end and tranny. Would a t-5 bolt up to a 350 and work? Allready got upgraded suspension, just need the v8 springs.
Old May 20, 2007 | 04:35 PM
Default RE: v6 swap
Depending on how much hp the 350 is pushing, the T5 is relatively weak.
Just get a th350, your making everything custom anyways if you go that route...I wouldn't put an old engine in a new car, it would just feel wierd, maybe cool tho
Old May 21, 2007 | 01:44 PM
AlfredB18's Avatar
Default RE: v6 swap
ORIGINAL: CamaroKid16
Cramming a carb under that cowl....pricey.
Buying gauges that work without the computer being in the car....added expense.
3800_seriesII
Aug 14, 2012 07:24 AM
9434V6
Sep 8, 2011 11:51 AM
xXChipXx
Aug 1, 2010 10:39 PM
miclo88
Oct 15, 2009 07:38 PM
85z285.0
Jun 2, 2007 03:19 PM
