V6 Camaro Tires Rubbing
Not exactly what you're asking, but for one thing, you need these in addition to your bump stops for 17" and bigger wheels:
http://www.hawksthirdgenparts.com/ca...erspacers.aspx
or these poly all-in-one units:
http://www.hawksthirdgenparts.com/ca...opnewgm-1.aspx
i have 18x9 (i think) corvette c5 wheels on the rear of my car, and they rub when taking corners fast. I know it rubs on a little bump inside the fender well. I plan to fix by introducing the fender well to mr. sledge hammer
You need what I posted, at the least.
Damn do I really need those? You don't think the 1 inch spacer will fix it completely? I also plan on lowering it, would that give me any new problems with my wheel size? (I'm lowering it like 1.4in in the back) You need those bump stops only for the rear right?
Definitely need them, rear only. Keep in mind those are for 17", so with 18", you may still have a little issue, but less with the spacer.
I didn't say he needed poly, but he needs the jounce spacers.
There is also a poly version that already has it integrated.
markinnaples
10
06-07-2015 09:06 PM
