Under the hood noise... (?)
Old Jul 21, 2006 | 12:22 AM
V1cinity's Avatar
Default Under the hood noise... (?)
I have a 95 3.4L and there is some noise under my hood. Sounds like a chain being dragged across gravel or a bolt on a plate of metal that is being vibrated. Dad says it sounds like the A/C compressor. Only makes the noise when in gear. Not coming from the trannsmission area. Its on the lower left back area of the engine compartment if you're standing in front of the car centered.
Any ideas what it could be?
Old Jul 21, 2006 | 02:58 PM
V1cinity's Avatar
Default RE: Under the hood noise... (?)
Can anyone tell me the order of the pulley system starting at the harmonic balencer and going clockwise? I think I found the loose part
Old Jul 21, 2006 | 05:34 PM
There should be a diagram stuck somewhere under the hood.
Otherwise, going clockwise from the crank pulley:
1) Under crank pulley (ribbed side)
2) Top of belt tensioner ((smooth side)
3) Under AC compressor (ribbed side)
4) Over altenator pulley (ribbed side)
5) Under water pump pulley (smooth side)
6) Over power steering pulley (ribbed side)
But why does it make noise only when in gear?? Those pulleys are always turning.
Old Jul 21, 2006 | 05:59 PM
MadMikeZ28's Avatar
Could be a loose bracket or missing bolts and while the car is in gear it is under a load and makes the engine vibrate a little more.
Old Jul 21, 2006 | 06:15 PM
V1cinity's Avatar
Well. I dont think its the pulleys after all. Took it to the local autozone and they scanned it, altought it didnt come back with anything. The tech guy there says to change my transmission fluid and filter. Seems to be louder with a bigger load on the engine like ac going, lights, but when put into neutral...it sounds fine, even with all the extras pulling on the engine.
So only in gear it makes the noise. Add more of a load...that sound picks up and gets louder. Dad still thinks its the A/C compressor. I'm starting to think its the trans. I can try to get a video of whats goin on and post it on you tube for your veiwing pleasure and to see if you might know what it is.
oh and as for the diagram...There isnt any stickers or labels under the hood. Someone took them off or maybe the heat and elements made them wear off.
Old Jul 21, 2006 | 06:34 PM
V1cinity's Avatar
http://www.transmissioncenter.net/TransmissionNoise.htm
The torque converter part sounds right on the money of what problem Im having. Will a transmission fluid flush and refill and new filter fix this issue?
Old Jul 21, 2006 | 10:45 PM
V1cinity's Avatar
Ok, nvm. I found the problem and it was the catalytic converter. Apparently I hit a speed bump too hard and it broke the pottery in there. Gonna get it fixed soon. Thanks all for the suggestions and help.
B_Dubya
Mar 27, 2015 02:10 PM
jayorr42AL
Nov 23, 2014 04:21 AM
Failed Devices
Jun 30, 2009 05:21 PM
ridinbikes247
Jan 10, 2007 07:00 PM
ScottD
Oct 27, 2006 06:37 PM
