True Dual? ?
#23
umm. why couldn't you just take one pipe over the axel on each side, like a vette? custom fab some hangers. if you do that though, i'd make a X-pipe somewhere in there. either before the axle, after the cats, or even, after you come over axel. the only hard part will be fitting 2 mufflers in there, might need to make each pipe go to opposite side, or use glass packs as mufflers and tips, as soon as the pipe straightens after axel.
#24
ORIGINAL: evilkal
It's not about power... It's about the sound. Exhaust is ALL about sound.
ORIGINAL: Alih
yes it sounds different, but it wont help performance muchunless you are pushing some real hp numbers
YES, you will gain even more horse with bigger pipes / dual pipes, BUT it moves your TQ curve up, meaning, instead of making max TQ @ say 3500, you now make it at 4000. which is what makes you more Horse, as Horse power is realted to TQ * RPM. this is just a example.
now, for a v6, because you dont have much TQ to start out with, i'd try to keep your low end TQ. plus, you can't rev higher than 5500 if i remeber correctly. if you go duals, i'd do 2".
#25
Actually most of the V6 exhausts are 2.25 if I remember correctly. MIne was at least. And you can rev to about 6100 before you lose your power curve on a stock 6 (if I remember right). Rev limiter kicks at 5900.
#26
ORIGINAL: evilkal
and really, 2.25? i had magnaflow on mine, and it was 2.5 ID. it's funny.... the exhaust on my ION is i beleave 2.75, and 1.5 primaries, wehre the v6 primaries are like 1.25.
