trouble codes
Old 02-04-2010, 03:44 PM
thetal1's Avatar
I have an ez-scan 3000
Old 02-04-2010, 04:33 PM
libertyforall1776's Avatar
First thing, make sure your 3000 has the latest firmware (V4.07), if not, update it:
http://autoxray.com/tool_download.php
Old 02-04-2010, 04:49 PM
thetal1's Avatar
i need a computer with a serial port and xp
my comp just has xp so i am looking for someone who has an old comp
Old 02-04-2010, 08:25 PM
USB (Universal SERIAL Bus) is a serial port -- if you have the USB Autoxray cable (or you can order it from them).
Else you can get one of these to convert USB to older style Serial 9-pin port:
http://www.tripplite.com/en/products...xtModelID=3914
Old 02-04-2010, 08:33 PM
thetal1's Avatar
I will eventually but ill just go to someone's house
Old 02-04-2010, 08:54 PM
SgCamaro's Avatar
Im not too knowledgeable on alarm systems, but to get an auto start system on a manual trans, Ive heard they have to do something to the clutch sensor to trick it into thinking the clutch pedal is pushed in.otherwise, the car will not start.
the code 39 must be due to that. there may not even be any problem with it, the computer may just be throwing the code because of the changes made by the shop
Old 02-04-2010, 09:06 PM
thetal1's Avatar
Thank you I knew I was missing something and that was it.
91camaropalmer
03-27-2010 10:52 AM
thetal1
12-23-2009 08:02 PM
myhorsepower.com
09-22-2008 07:28 PM
twistedpyro
11-26-2007 05:35 PM
v6camaro00
04-05-2007 07:11 PM
Quick Reply: trouble codes
