Transmission removal
Old Dec 4, 2006 | 01:42 AM
460cougarguy's Avatar
Default Transmission removal
I have a 98 V6 camaro and i'm trying to remove the t5 manual transmission. I have everything disconnected but when I try to pull the transmission back the top of the bellhousing hits the tunnel. With this happening the input shaft doesn't completely clear the way to come out. Any ideas on how the trans should be removed? Any help would be greatly appreciated.
Thanks,
Shawn
Old Dec 4, 2006 | 09:52 PM
shnormo's Avatar
Default RE: Transmission removal
I'm going to assume that you took the trans crossmember out right? Well I'd put some wood on the front end of the motor so that way it tilts and pivots on the motor mounts.
Nytric
12
May 5, 2012 10:24 PM
dsinclair999
Feb 21, 2011 11:24 AM
denial
May 14, 2010 10:45 PM
Z28midwest_08
82-92 V8 Tech
Jun 25, 2008 09:44 PM
camaro kid
Sep 12, 2006 01:47 AM
