Transmission Jumps out of reverse
RE: Transmission Jumps out of reverse
Basically you have a transmission problem which will require dismantling the transmissio. It could be worn out parts, a weak spring, linkage adjustment, etc.. The problem is that everything is inside of the transmission case.
Theresa Fox Allen
02-09-2015 12:38 PM
