throttle sensor replacement
Old Aug 27, 2008 | 04:26 PM
02CamaroV6's Avatar
Default throttle sensor replacement
Hesitation at acceleration...eventually loss of power. Cleaned MAF and some improvement. Thinking TPS needs checout or replacement. How do you replace the TPS?
Old Aug 27, 2008 | 06:23 PM
evilkal's Avatar
Default RE: throttle sensor replacement
EDIT: I may have midunderstood you... Is it a misfire or does your car hesitate to deliver power when you press the pedal?
Old Aug 27, 2008 | 08:51 PM
02StanGT's Avatar
Unplug it, remove a couple of screws, remove it, install new one, replace screws, plug it back in.
Old Aug 28, 2008 | 11:16 AM
greg w's Avatar
What 02stang said, maybe a little anti sieze on the screws and dielectric grease in the pigtail
mezzyshredder
May 20, 2012 06:03 AM
kimbers99camaro
Jun 13, 2010 09:20 PM
ramkid318
LS Series Tech
Aug 19, 2008 06:07 PM
jfoote
Jan 21, 2008 07:31 PM
z28pete
Aug 29, 2007 10:32 AM
