Temp Gauge Goes Up Real Fast
Old Dec 20, 2008 | 01:15 PM
New2Camaro's Avatar
Default Temp Gauge Goes Up Real Fast
I have yet to get my 2000 on the road but I would like to get a list of what I might need. 2day I started it so the battery doesn't die and I let it run for a while and I got in and the temp gauge was at the bottom and I already knew the heat didn't work but I turned it on anyway and the temp gauge shot right up to about 200 degrees and stayed there (can't remember if the fan came on) and it sounded like the antifreeze was boiling and I do remember the night we brought the car home (wife drove) when I was checking it over it wasn't overheating but you can hear the antifreeze was bubbling. Thanks.
Old Dec 20, 2008 | 05:10 PM
02StanGT's Avatar
Default RE: Temp Gauge Goes Up Real Fast
How fast the the temp gauge shoot up? Where do you hear the antifreeze bubbling? Lastly, how is the coolant level?
Old Dec 20, 2008 | 07:08 PM
evilkal's Avatar
Since the heat doesn't work....
1. Check the thermostat
2. Make sure the air has been bled out. There is a brass nut on the thermostat housing to unscrew while the engine is running. Let it go until coolant comes out.
3. Check and see if your heater core is clogged.
4. Make sure your radiator cap isn't busted.
Patrick Quentin Musick
Mar 14, 2013 10:25 PM
Mitch Upton
67-69 V8 Tech
Sep 9, 2011 04:04 PM
imcdowel
Mar 9, 2010 06:16 PM
josh95camaro
Oct 9, 2009 10:15 AM
94greenZ
Oct 6, 2009 04:25 PM
