LT1/LT4 Tech 1993-1997
Temp gauge
Old Oct 5, 2009 | 06:42 AM
94greenZ's Avatar
Default Temp gauge
Hi everyone,
Got in my 94 Z this morning, and within about 3 minutes my temp gauge was pegged past 260. No way it was already hot as it's below 60 degrees and raining. About a 15 minute drive to work, occasionaly, the temp would drop back to about half way the gauge for a moment, only to peg out again shortly after. Engine is in no way even close to hot...Any ideas? Thanks in advance....PS, did notice the heater was not working...blowing cool air.
Old Oct 5, 2009 | 08:11 AM
Bad temp sender, wire from sender shorting to ground, bad gage. Takr your pick.
Old Oct 5, 2009 | 08:16 AM
94greenZ's Avatar
Thanks for the reply, but would that affect the heater not working? Thanks
Old Oct 5, 2009 | 09:38 AM
sure sounds like its low on coolant. yes a motor can get that hot in a few minutes if theres no coolant and the heater will not work or will do what u are saying.
Old Oct 6, 2009 | 04:25 PM
carguylt1's Avatar
how hot would the heater normaly get in that time. You probably have light that would tell you it is low of coolant don't trust it chack it your self crab is prob. rite if you have coolant it maybe something to do with the thermostat.
Mitch Upton
67-69 V8 Tech
Sep 9, 2011 04:04 PM
Dana
Jun 16, 2011 11:20 PM
imcdowel
Mar 9, 2010 06:16 PM
josh95camaro
Oct 9, 2009 10:15 AM
57dv
Aug 20, 2006 05:14 PM
