Taking fuel lines off the fuel rail
Wow I can't believe I stumped the forum! lol!
Here's the instructions I have. What I need to know is step 8. Anyone know what tool it is or if there's something else I can use?
14. Remove and discard O-rings from fuel rail
REMOVE OR DISCONNECT
1. Turn ignition "OFF"
2. Disconnect negative battery cable
3. Relieve fuel system pressure
4. Disconnect quick connect fittings at engine fuel pipes
5. Slide rubber dust covers from quick connect fittings at engine fuel pipes
6. Grasp both sides of fitting. Twist female connector 1/4 turn in each direction to loosen any dirt within fitting.
7. Using compressed air, blow dirt out of fitting
8. Choose correct tool from J 37088-A or J 39504 tool set for size of fitting. Insert tool into female connector, then push/pull inward to release
locking tabs.
9 Pull connection apart
locking tabs.
CAUTION:
If it is necessary to remove rust or burrs from fuel pipe, use emery cloth in a radial motion with the pipe end to prevent damage to
O-ring sealing surface.
- Using a clean shop towel, wipe off male pipe end.
- Inspect both ends of fitting for dirt and burrs clean or replace components/assemblies as required.
10. Remove engine fuel pipe retaining bolts
11. Remove accelerator cable from routing clip
12. Remove fuel tube retainer from fuel rail
13. Remove engine fuel pipes
heres a universal set
http://www.amazon.com/gp/product/B00...AR4D9WNNQKQB2K
and a fuel line only set.
http://www.autozone.com/autozone/acc...ntifier=246367
royco95
08-02-2015 10:25 AM
