T-56 tranny on 3.8 V6
You can put a T-56 in 1974 Pacer. The question should be what work is required. I would assume the T-56 Crossmember and shifter would bolt up. Bell housing, clutch and input shaft would be the problems. If you have the type of shop that can make one offs of those things then its a piece of cake. I don't have the answer of what exists but I would love to know if the info was out there.
