supercharger
Old Feb 16, 2012 | 09:45 PM
93bumblebeeCAMARO's Avatar
Default supercharger
i found this supercharger for the late 90's gm and i have a 93 3.4 now the ad says its for the 3.8 im wondering if it will fit my 3.4 and work properly on a different note i wanna know if i get the whole front clip of a 98-2002 camaro will it fit onto my 93
Old Feb 16, 2012 | 09:50 PM
BasicConcepts's Avatar
Technical User
no the supercharger wont work your engine wont handle it
yes you can put the front clip from the 98+ on your car you need the fenders bumper hood headlights headlight bracket and the 2 brackets that hold the bumper to the fenders
Old Feb 16, 2012 | 09:56 PM
thanks basic and damn that sucks i was looking forward to installing the supercharger
Old Feb 16, 2012 | 10:46 PM
Technical User
ya sadly you have one of the worst engines ever designed the heads are junk and the lower intake is restrictive putting boost to that engine will destroy it
Old Feb 17, 2012 | 03:28 PM
RedSled99's Avatar
What is a good supercharger for the 3.8L? Or is a turbo better?
Old Feb 17, 2012 | 04:49 PM
Technical User
start your own thread... you need to get the idea of boost out of your mind it can be done but its not cheap or easy plus theres really no room at all for a turbo/supercharger... and no the supercharger from a gtp wont work
Old Feb 17, 2012 | 06:41 PM
speaking of the gtp supercharger heres a question i know has been asked b4... i know theres threads about switching the 3.4 for the 3.8 but it doesnt say supercharged 3.8, can i swap it out the 3.4 for the impala 3.8 supercharged from the impala? will i have to modify the mounts? also what about if i switched out the heads from 3.4 to 3.8, is that possible?
Old Feb 17, 2012 | 06:54 PM
Technical User
no you can bolt a sc to any 3800 engine the problem is the throttle body would be where your radio is
Old Feb 17, 2012 | 06:55 PM
The 3800 has nothing in common with the 3.4 except the trans bolt pattern. The GM 3800 superchager will not work because intake is facing the wrong way. the throttle body would be about where your radio is.
Try some research, a quick search will show all this stuff has been cover 9003 times
Old Feb 17, 2012 | 06:57 PM
Technical User
9004 now
hotss10
2010+ V8 Tech
17
Apr 25, 2010 01:53 AM
Wingman
Oct 21, 2009 03:18 PM
Antwan
Sep 23, 2009 10:08 PM
stockv6auto
Sep 11, 2009 09:48 PM
camarohelp
Aug 2, 2008 12:30 AM
