Spark plugs and wires
Old Jan 11, 2011 | 06:35 PM
C4r1b0u's Avatar
Default Spark plugs and wires
Is there an easy way to get to them in a 3.4? Also how hard is it to change wires?
Old Jan 11, 2011 | 08:20 PM
mrfreez's Avatar
It's pretty easy to change them. If your car has AC, you'll need a long extension for your socket to go through the AC lines on the passenger side.
Old Jan 12, 2011 | 12:22 AM
Massey's Avatar
I think the 3.4L engine is the only one that all plugs can be changed from the top. It took me about 1/2 and hour to do my friends car.
Massey
Old Jan 14, 2011 | 01:05 PM
C4r1b0u's Avatar
Alright, what plugs and wires would you recommend for like fuel efficiency?
Old Jan 14, 2011 | 06:19 PM
mrfreez's Avatar
AC Delco wires and platinum plugs.
Old Jan 14, 2011 | 07:22 PM
Massey's Avatar
I agree with the platinum plugs as the minimum, go with double plat or iridium and take the next 100K miles off from worrying about them. Wires I prefer Borg Warner. They have been around forever and the wires are lifetime warranty. Get a little dielectric grease to put in the boots of the plug and coil side to help extend the life of the wires as well.
Massey
Old Jan 15, 2011 | 10:39 AM
joseph_zlnsk's Avatar
I had to use a 3/8 swivel on mine to make removal of the plugs from the passenger side easier. I put a little bit of anti seize on the threads of the plugs as well. Just a little bit. Cause it is a SOB when something else breaks and you gotta pull em to compression test or check your plugs and one gets stuck
talaboy1992
82-92 V8 Tech
Jul 2, 2011 06:02 PM
greenmachine96
Apr 11, 2011 08:55 PM
kidd75
67-69 V8 Tech
Dec 1, 2010 02:48 PM
CaosCamaro
May 15, 2009 01:42 PM
