Spark Plug Wires
Old Jan 18, 2008 | 09:39 PM
MAYH3M's Avatar
Default RE: Spark Plug Wires
Some of your Fuel Injectors may have been clogged. Hopefully the Garage Door was open? lol
Old Jan 18, 2008 | 09:43 PM
3.4CamaroCDOG's Avatar
lol it was open it only smoked real bad for only 20 seconds so is this normal ima wake up tommorrow and let it run a minute
so wat can clogged injectors do?
also my temperature gauge sensor thing for the gauge inside the car is broke but my car was misfiring before it got broke...... im like lost it drives good sometimes then it doesnt......
Old Jan 19, 2008 | 02:55 PM
MAYH3M's Avatar
ORIGINAL: 3.4CamaroCDOG
If they're clogged, they wont spray, or they'll spray very little, which could, If I remember correctly, cause misfire sometimes, but I could be wrong.
Old Jan 19, 2008 | 03:19 PM
aw well hopefully this injector cleaner works
also do u kno if the coolant temperature sensors can cause a misfire because not sending the right info for the fuel system
Old Jan 19, 2008 | 03:55 PM
MAYH3M's Avatar
That, I don't know. I'm sure one of the guys on the forums would though
Old Jan 19, 2008 | 04:04 PM
well thanxs anyway
Old Jan 19, 2008 | 06:35 PM
02StanGT's Avatar
Yes, if the coolant temperature sensor is broke, it will send incorrect readings to the PCM. The PCM will see the reading and add or subtract more fuel, which could cause misfire.
Old Jan 19, 2008 | 06:39 PM
OMG THE WORSE CASE HAPPENED
I CALLED AUTOZONE AND WAS TELLIN HER HOW WHEN I PARK MY CAR AND COME BACK IN LIKE 1 MINUTE AND IT WONT START EASILY SHE TOLD ME IT COULD BE MY FUEL INJECTORS CAUSE I HAVE BEEN RUNNING MY CAR LOW ALOT(I KNO IM NOT SUPPOSE TO BUT MY GAS HAND BE ACTIN UP). I PUT SOME FUEL SYSTEM CLEANER IN AND HOPING TO GOD THAT IT WORKS. HOW MANY TIMES CAN I PUT FUEL INJECTOR CLEANER IN MY CAR?
WILL IT EVENTUALLY WORK?
IS THERE A WAY TO TAKE THE INJECTORS OUT AND THEM OR THEY HAVE TO BE REPLACED?
WHERE ARE THEY LOCATED?
SORRY FOR THE LIST OF QUESTIONS
Volcente
Jan 28, 2012 04:13 PM
JaySan
Mar 22, 2008 11:40 PM
KoRN_Munky
Dec 24, 2006 10:13 PM
Saint_Ali
Jun 22, 2006 08:37 PM
