Sealant for #4 Main Bearing cap
Old Aug 3, 2016 | 10:10 PM
afbryant's Avatar
Default Sealant for #4 Main Bearing cap
Trying to get the crankshaft installed in my 2000 3.8. The manual says to put a sealant between the #4 main cap and the block. Does anyone know exactly where this sealant should go?
Old Aug 4, 2016 | 12:06 AM
afbryant's Avatar
It would seem more likely it is talking about just the 2 corners where the edges are beveled(chamfered)???
Old Aug 4, 2016 | 07:25 AM
Everett#2390's Avatar
Clean both mating surfaces with either lacquer thinner or BraKleen®.
Then on the block, lay a 1/16 inch continuous bead from the pan gasket to the flange seal.
The idea is sealing the cap from oil seepage but keeping the sealant volume low preventing fretting - walking - between the cap and block.
zambu
70-81 V8 Tech
Jan 9, 2015 03:10 PM
88maroz28
Jun 23, 2012 05:42 PM
sportsman70004
Aug 13, 2010 07:29 AM
hotrodb
Apr 29, 2007 07:20 PM
gotalcoholmanup
May 7, 2006 03:15 PM
