Main Bearing oil clearance question
Old Jun 23, 2012 | 02:06 PM
88maroz28's Avatar
Default Main Bearing oil clearance question
So picked up 88 z28 with a blow 305.
im building a 350 out of a k1500 (crate engine) to put it in
My main bearing clearance are all good except #4. Just had the crank polished & got new bearing all 123 and 5 are.025mm in spec but #4 is around .076 which is not in spec.
so my question is can i just get new bearing for #4 with out re grinding the whole crank?
I'm thinking get an under sized bearing of .026 mm am i right?
Can i just put an under size bearing on #4 where my problem is?
Spec i have are 2,3,4, .025-.064 ; 1 .025-.038 ;5 .064-.089mm (mitchell)
Old Jun 23, 2012 | 05:42 PM
No problem with doing that, as long as the crank journal is OK and the main cap is not distorted, and you can find a proper size bearing, You should mike the crank journal and then order accordingly. From what you are saying #4 is .051 smaller than the other 3, so .026 under size will still result in excessive clearance.
1989_RALLYSPORT
82-92 V8 Tech
Apr 28, 2011 06:21 PM
sportsman70004
Aug 13, 2010 07:29 AM
CraZ28
Feb 22, 2010 09:45 PM
hotrodb
Apr 29, 2007 07:20 PM
Saint_Ali
Jul 20, 2006 04:15 AM
