Reuse main cap bolts?
Old Jan 9, 2015 | 04:54 AM
zambu's Avatar
Default Reuse main cap bolts?
I am assembling my engine (307, mild upgrade to 200hp, cr 8.9), after cleaning, changing bearings, etc. Can I reuse the main cap bolts? So far they look fine. I know they are not expensive to buy, just takes a long time (and expensive shipment) to my place.
Old Jan 9, 2015 | 06:58 AM
flat tire's Avatar
when I was building engines I always used the original bolts. never had a failure due to bolts
Old Jan 9, 2015 | 07:39 AM
YAV8's Avatar
Same here, just be sure that you get the main caps back on the same ones you took them off of. Same with the rod caps.
Old Jan 9, 2015 | 07:55 AM
I 3rd that. Those style bolts are reusable, it's the torque to yield bolts that aren't.
Old Jan 9, 2015 | 08:20 AM
zambu's Avatar
Thanks for the comments. Caps are marked, so should be fine.
I was stupid enough to buy a set of new small journal bolts...had to learn that small block is not small journal
Old Jan 9, 2015 | 03:10 PM
YAV8's Avatar
It was back in the day before the large journal rods cam along. We use to spin a 327+.030 back in the early days to 8200 rpms, and it stayed together.
s4l
70-81 V8 Tech
Feb 12, 2011 11:43 PM
ScottD
Dec 4, 2009 11:37 PM
smpsn84
82-92 V8 Tech
May 6, 2009 08:14 PM
awake1630
Apr 2, 2008 11:04 AM
mcge383
Nov 10, 2006 11:53 AM
