Competition Engineering traction bars. U bolts vs J bolts
Old Mar 31, 2008 | 09:30 PM
awake1630's Avatar
Default Competition Engineering traction bars. U bolts vs J bolts
I have 69 camaro with 12 bolt and multileaf springs. it has 4:10s in it.
THe car is a 4 speed car with a 350 with around 470 horse.
My question is i just got a set of Comp. Engineering tractions bars from a friend.
I was wondering if i should use the J bolts supplied with them
or the oringinal U bolts.
Which setup is more beneficial. Any suggestions are greatly appreciated. Do you think one setup is superior to the other.
J bolts Vs. U bolts. Which one is a better way to set up the traction bars.
Old Apr 2, 2008 | 06:22 AM
awake1630's Avatar
Default RE: Competition Engineering traction bars. U bolts vs J bolts
anybody running traction bars out there?
Old Apr 2, 2008 | 07:36 AM
FlightMechYJ68's Avatar
If they aren't I'd hope they would, they improve handling IMMENSLY... I want to get that Hotchkis one for the rear.... VERY NICE!...
Old Apr 2, 2008 | 11:04 AM
I have mine mounted on with the U-bolts. The J-bolts give you the ability to give more or less preload on the front of the bars to adjust for a straighter launch (less body twist). Unless you're constantly racing your car, the benefits won't be as important. But then, if I had the J-bolts in my hand, I would probably wind up playing with them instead of the U-bolts.
jimm418
May 30, 2014 12:58 PM
77nomad
Nov 21, 2009 11:28 AM
dusty
Aug 17, 2006 12:21 PM
bowtieguy
Apr 26, 2006 11:09 PM
rashii12345
Mar 4, 2006 12:43 AM
